what dampener will fit my bike
I have had my 01 yz250 for a couple months now, and when i bought the bike it has had the mounts for a steering stabilizer. It looks like its for a scotts stabilizer, but im not sure i was wondering if you guys could tell me? The mount has no company name on it.
My best guess would be Scotts also, by the look of the post is why I say that and I don't know what the two front mounting holes are for on your bar clamps.
Simply remove the tower pin and go up to one of your buddy’s bikes that has a Scotts on it on see if your pin will fit in his dampers arm. If it's for a GPR the pin is larger in diameter and won't fit the arm slot of the Scotts.
Having said that however the bottom portion of either pins (Scotts or GPR) will fit in either post, I know this because I have the option to run both dampers because my bar clamp has mounting holes for both dampers but those holes are both located at the rear of the bar clamps.
