crf crank question
i put new bearing in the cases and a new crank too. how much end play in the rod should i have?
Chech the book. I don't have mine handy or I would check. Up and dowm there should be 0:thumbsup:
sorry, i meant to say play in the crank. i can move it side to side in the cases and want to make sure there isnt too much play. anyone know the measurement for that?
well,---it will move side to side quite abit untill you tighten down the rt PTO side crank gears and bolt to 90 ft lbs---,and that will pull the crank over to the rt and center it all up in the cases ,
then you should get just alittle or no side to side play when cold ,---with oil on the bearings and the cases all warmed up you will have no play side to side or any up and down at all ---:applause:
