big bore kit
Im not into the big bore kits much but a customer sent me an Athena kit to look @ and i have to say its done right i was suprized to see that Athena uses a iron liner that has been nikasiled i had done the same thing on some custom cylinders for a diferent aplication and had very good results you end up with a very stiff liner and still have all the benifits of the nikasil .heat transfer is not an issue and may even be better for power with more controlled combustion temperatures .
great to hear, I have the Athena 280 kit that Santa brought me still in the box. I'll be calling you soon to order the 07 R head to go with it -
SPRING is just around the corner !!!
Thats good to hear for future upgrades :applause:
Does thumper racing 270 use a nikasil coated cylinder?
I have a TR 270 kit installed.
I will be replacing my piston relativley soon.
I would like to get my cylinder Nikasil plated when I take it apart for a rebuild.
Is it too late since I've already run a piston in there?
Do I need to go bigger on the bore to make up the difference of plating thickness? Or do I just get it honed out and they plate it?
Hey Ron, would a CRF 450 carb be to big to put with the Athena 280? if it was jetted right. Thinking about this for my X for a few extra ponies.
Thanks
