TTR 230 air/fuel mix screw drilling out
I need help (visuals if possible) of how to drill out the air/fuel mixture screw on the TTR 230.:applause:
thanks
Drill a sheetmetal screw into the center of the brass plug maybe a 1/4 of an inch and pull it out with a pair of pliers.
Sheet metal screw method works best I think.
I carefully drilled 1/8" hole into the bras cap, screwed in a small sheet metal screw then pulled it out with a pair of pliers. Came out very easy.
(click on the pics to enlarge)
