The Carb specs for XR80
I want to verify a baseline for my 1980 XL to XR80 convert.
Can one of you with tuning knowledge throw me bone.
What carb should be on this machine for a start A Keihin PC10,20 etc.
My main jet is at sea level a 105 per BBR and Powroll, pilot is a 35 per same.
I have not looked at what needle, slide, or emulsion tube is in it (the XL parts are different). The carb was replaced a while back. The piston is a new, one over wiseco, the pipe is a Powroll, the cam is a new old stock 1980 XR. needle position? Type needle? mix screw setting? What should be stamped on the carb PC???
in addition any final drive suggestions? thanks Rob
This is from the Clymer XL/XR 75-100 1975-1990 Manual.
Not the best, but better than nothing.
1980-1984 XL80S
Carb PF65B
Main 72
Slow N/A
Pilot 2-3/4 turns out
Needle Fixed
Float 16.6mm (0.65 in)
Idle speed 1500 +/- 100
ALL XR80
PC10A
Main 92
Slow 35
Pilot 1-1/2 turns out
Needle 4th groove (On my XR80 3rd, middle, worked 100% better!)
Float 20.0 mm (0.787 in)
I put a new carb on my 1979 XR80 jetted to these specs.
It ran like crap mid throttle. Dropped the needle to the 3rd, mid setting, and it ran great. I could test a larger main jet, but this bike is for my wife and son to learn on. Maximum throttle is not a concern. I can start it with my arm. Easy starting is a concern.
