Electric Start Problems Need Help!!!!
I took of my electric start because I was racing mx and needed to loose the extra poundage. What I took of was the button, battery and the starter relay. I am trying to put it back together now. I put in a new battery and reconected the button. I also put on a new relay and the electric start still dosent work. Any suggestions on what I can do. Thanks,
Joe
Did you pull off any of the wires that connect to the starter. How long did you have the electric start disconnected. I wonder if running it without the electric start caused that fuse to burn out for some reason. Check that fuse on the back right hand side under the numberplate
