Kx 125 Mods
I have a 04 kx 125 that I want to mod out. I was thinking of gettin the pro circuit pipe (one for bottom end) is pro-circuit alot better than FMF or about the same. ALso I was thinking of getting V-Force reeds for it. Are the Boyesen super stock fiber reeds as good as the V-Force because then I wouldnt have to buy the cage. I was also thinkin of getting Power Now for it. Anybody have the power now and does it help alot? Any other mods I should think about. Im also ganna try running different sprockets for different tracks.
I like the stock pipe better than the pc pipe.Gearing 13/52. I run stock reeds.Make sure the bikes jetting is right.Mine is 35,410,needle 3 clip.I have a pc pipe for sale.
I have a mod KX125 with PC pipe and love it. I also have V-Force 3 reeds and tons of other mods. I am pregnant right now but my husband is about to get my bike ready fro me to ride again and we will not be going with V-Force reeds again. They keep getting worn on the edge so we are going to go with boyesen just to see if the edges don't get worn as fast.
The stock pipe on the '04 125 is very good. None of the aftermarket pipes are significantly better. They will all add power somewhere in the power curve, but at the expense of power elsewhere in the curve. The stock pipe really is a good compromise. And no one makes a "torque" pipe for a 125. The FMF Fatty is a mid-range pipe, and they also make a rev pipe. The Pro Circuit pipe is similar to the FMF Rev pipe.
The V-Force is more hype than anything. It will slightly improve throttle response on the bottom, and that's about it. The Boyesen Rad Valve is a much better product. If you know how to jet (you will have to re-jet for the Rad Valve) it will produce gains across the entire rev range, especially in the mid and up.
In my experience, almost all aftermarket reeds perform as well as the V-Force, at substantially less cost. Think about it. The V-Force is so popular because it doesn't require re-jetting. If it doesn't require re-jetting, then it isn't making any significant changes in the air flow to the engine. If it doesn't change the air flow, then it also can't change the performance very much.
The Power Now is a waste of money on that bike. It is only an effective mod on bikes that have over-sized carbs, like the CRF250R and the SX125. On your bike, the difference in performance will not be enough to justify the cost.
Porting. It's the best bang-for-the-buck mod you can do to a two-stroke. For less than the cost of an exhaust sytem, you can greatly increase the performance of your engine, and even tailor the power curve to suit your needs and desires. I would get a port job before I bought any bolt-ons.
Also suspension. Having your suspension professionally tailored to you is a far better mod than any engine work, and will improve your speed, control, comfort, and confidence more than any amount of power increase will ever do. Suspension should always be your first mod in my opinion.
No matter what other mods you do, sprockets are always a wise investment. Different riding conditions need different gearing. Deep sand and tight tracks need shorter gearing for added punch. Long straights and hard dirt need taller gearing for more speed and less hit.
I will sell the pc pipe for 100 bucks.It is in excellent shape,like new.
I actually already bought a Pro-Circuit pipe just this morning. Thanks for letting me know that the power now was a waste of money. I will definaltly look into porting it. Right now I feel my suspension is ok but will also look into uprading that too.
After experiencing what suspension feels like after it has been professionally tailored just for you, you'll wonder how you ever thought your stock suspension was any good.
Well Im definatly going to look into, talked to some kids I race with and they said get suspension too. Could I just get different springs and stuff. Other wise how much would suspension cost?
WEll the pipe I bought for it doesnt fit because its a 03 pipe and I have a 04. Do u still have ur pipe for sale KXJIM? If so how much and what is it does silencer come with?
