Need help to find the oil drain plugs on SM610
Hi,
would any one know about the oil drain plugs on SM610 - the service manual says there are 2 with screws andd and seals but i found only one screw (on opposite underside to il filter) and it did not drain much. there was another what looked like a plug but it had a large recessed female allen key type socket - and the manual said it should be a screw.......
any wisdom on this issue greatly appreciated!
Anthony
The plug with the allen is the other drain. However, instead of removing the plug with the allen, drain the oil from the hex head plug and the left side filter screen cover. You will have to remove the left side screens to clean them anyway. Leave the bike on the side stand when you do this to ensure a complete drain.
