Exhaust Flange Question?
i have a FMF SST pipe on my 01 cr 125. the mounting flange busted and the pipe will no longer connect to the head!!:applause: so i am looking to buy another SST pipe for my bike.. i also need the gaskets and hardware... does the OEM hardware work with the FMF pipes or do i need to get the FMF hardware to mount the pipe?? Does the pipe come with hardware???
thanks in advance!!
:eek: o so i can buy and replace the flange on the old pipe and just reinstall it>>:applause:
Maybe a picture of the problem would help.
You don't need a whole new pipe if just the flange broke. 02 CR250s had the problem of the exhaust flange breaking. I spend like 30 bucks and just bought a Pro Circuit one. As long as the exhaust pipe isn't messed up, then there would be no need to change it. :applause:
ok awsome.. cuz the pipe itself is fine.. its just the flange broken!!! and i found that pro circuit flange in dennis kirk:thumbsup: so ill be getting that since they say that it is much stronger than stock!! thanks for ur help
