Just fitted E Model CRD rad braces to my S
In a word - b*satrd
If you aint got access to a welder then forget it
right side
Horn has to be relocated to elswhere (mine went under the h/light), had make a small right angle bracket to mount it to where the horn used to mounted
Left side
Fan has to go.
No bracket on the frame to mount the rad brace to - solution:- make one and weld it to the frame.
Rad brace also fouls my Clarke 14.7 litre tank. Solution:- cut and reshape rad brace
H/Light brkts also touch cross bars of the rad braces at full lock. solution:- grind headlight bkts to allow clearance.
What I thought would be an hours jobs turn into an all weekender. What PITA:banghead:
