Mcain Valley
Does anybody know if they enforce spark arrestors there?
Thanks!
I was at McCain two Sunday's ago....rangers rolled in and checked all bikes that were in the staging area.
BTW....what's the typical fine for not having a spark arrestor in CA??
I wanted to take this oportunity to recall the 300,000 acre cedar fire in san diego co. and the jackass who started it maybe the fine should be casteration
As near as I can tell, spark arrestors are covered under:
CALIFORNIA CODES
HEALTH AND SAFETY CODE
SECTION 13000-13011
http://www.aroundthecapitol.com/code/getcode.html?file=./hsc/12001-13000/13000-13011
The fine can range from $100/$500/$750 up to $1000.
Every person convicted of a violation of this section shall be
punished by a mandatory fine of not less than one hundred dollars
($100) nor more than one thousand dollars ($1,000) upon a first
conviction, by a mandatory fine of not less than five hundred dollars
($500) nor more than one thousand dollars ($1,000) upon a second
conviction, and by a mandatory fine of not less than seven hundred
fifty dollars ($750) nor more than one thousand dollars ($1,000) upon
a third or subsequent conviction.
The court may, in addition to the fine imposed upon a conviction,
require as a condition of probation, in addition to any other
condition, that any person convicted of a violation of this section
pick up litter at a time and place within the jurisdiction of the
court for not less than eight hours.
Thanks!
Enforced?! If they aren't, they should be by the riders! You included!
What's the cost of a SA Can, or insert ... that could save a disasterous fire?! My FMF 4.1 is $45... and I use it.
Ride with one, and the worry of enforcement is over. :applause:
