Rim Welding?
Has anyone ever had any welding done to sport bike rims? Im looking at getting the cush drive welded to the rim Of some cbr 600f2 rims. I was wondering how the tig welds would hold up.
Yes having the cush drive welded to the rim, i had to machine down the cush drive to fit the overall swingarm width & had to remove the outer cush drive bearing so theres no way for the cush drive hub to maintain contact. so i was thinking on welding it to the rim.
Welding to the hub parts should not be a problem. You will have to deal with the machining, fit-up, alignment, joint design, weld distortion and maybe some post weld machining.
