leaking 250
i have a 2001 cr250.it seems to be leaking oil from the stator side of the case.does anyone know how or if i can replace the seal with out splitting the case.:applause:
Yes you can. You'll need a flywheel puller to get the flywheel off. Then the seal is right there.
make sure that you DONT push the seal in too far when you replace it. you can plug the oil hole in the left side of the crank housing if you push in the seal too far, causing possible(probable) engine failure...:applause:
