VOR problem, pls help
i have a VOR 503sm and ive been loosing coolant.
the oil is not cloudy or milky, ive never noticed any white smoke out of the exhaust.
what numbers should be on the radiator cap? mine is 1.40, its different than all my other bikes. my others are all 1.1
i run engine ice coolant.
ive read all kinds of posts on this forum but none of the topics match my circumstances.
please help.
Try another pressure valve in the radiator cap. They sometimes become corroded from excessive coolant ratios and fail.They cost about $25 Australian. Lets hope that it is a simple problem. Put a small plastic bottle on the end of your overflow hose to see if the coolant is coming from the cap firstly.My 530 cap says 1.3 but anything above 1.1 is fine. Goodluck but if this isnt the problem we will coach you into the next stage of continuing VOR repairs.
so i was wrong and teh oil did have water in it. the rad cap is fine but the seal behind the waterpump is the culpret. ive got one on order with moto xotica now. bummer.
