DRZ400E steering stem, grease?
I've found that, while I'm away at college and my bike just sits, the steering stem will set up a little (handlebars don't want to turn). How can I grease it? The dirt bike world is new to me, and I can't remember seeing a grease fitting anywhere on there. Thanks a lot!
some guys have drilled and tapped a hole in the frame where the triple goes thru and put in a zerk to grease them.
I will post a pic later on of what a low hour stored inside lower bearing looks like.
this is one of the known trouble spots that needs attention no matter what year DRZ your riding....
this stem is outta a low hour E. It showed no signs of roughness while turning and you can see the minimal amount of grease the factory used in assembly on the upper bearing. DSC01455.jpg
