AP Squirt
How do you set the AP Timing? Does anybody have a start point for me to try? Also, What is the link for the Red Beard AP mod?
take the throttle housing cover off..and take off the subframe, air cleaner assembly. and air boot, make sure u can see into the venturi of the carb...
also take off the gas tank and place it on a table and reconnect the fuel hose back into the carb...with the carb off and hanging off the side of the frame....wack the throttle and time the ap quirt with the timing screw....try to adjust it so when u wack that throttle really fast, it barely misses the valve slide.....other than that u can measure the gap with a set of feeler gauges and match it to the spec. in ur manual
