Setting up for Asphalt?
I am going to be competing in a aspahlt race for 450cc dirtbikes. Anyhow, I was wanting to know what all would it take to make my CRF450 supermoto style?:applause:
you would need rims, because supermoto tires are 17inchers, and your moto rims are not(sadly, because rims are expensive), possibly lower gearing so you have more top speed, dont hold me to that, thats all i can think of off the top of my head, but i also think that you would need road race leathers because im not sure if the people holding the race would let you run the risk of sliding across asphalt in moto gear
You would also need to stiffen up the suspension a little bit also. I know the front dives down real hard under heavy braking.
My Yz426, this is the list of items
* Black Powder Coated Frame
trailtech endurance
Moose Easy Clutch (yes I got weak hands)
cycra probends
acerbis motard fender
acebis brake/tail light
acerbis diamond headlight
trailtech hi/low/kill switch
Wolf CDI 2 map ignition
wr250 stator
wr250 fly wheel
wr250 regulator
SDG seat
ALL 2004 YZ450 plastics
2004 gas tank / subframe/ R. master
Conti Force tires 120/30/17-F 160/70/17-R
Behr / Rad wheels no chain RUB at all
42t rear sprocket
ASV F3 clutch perch/ Brake lever
MotoMaster Brake setup/ stock master
Non Oring chain
IMS Pegs
Trailtech Kick Stand
Hot Cams intake and exhaust
Full Yoshi Ti
ProTaper's with GYTR Triple
