drz 400e overheating
I would run an OEM one, place a add in the classifieds for Auzuki parts, a 'WTB' one, many have taken their fans off and would probably sell it to you cheap. Then all you will need to get is the temp sensor to switch it on.
After several long trips into Mexico on my E , I eventually popped a hole in my coolant tank when it overheated last summer when I got stuck in a downtown traffic snarl in Matehaula.
I installed two small 80mm x 80mm 12v computer fans in front of my rads with zip ties and wired to my running light so they stay on all of the time. They weigh next to nothing and despite several thousand miles of hard running in and out of dirt/water etc they still work fine. The 100mm x 100 mm fans should also fit. Mine are sandwiched between the unibiker guards and rads.
