bend radiator
I have a question about a 2007 yz250f. I was riding today and I crashed into my friends rear fender which unfortunately bent the raidiator and the plastic protective shrowd a bit. There are no leaks of coolant but i just want to know if its still safe to ride the bike or should i get that checked out? :applause:
I had a bent left radiator on my 04 for a full year and never had problems. Depending on how bent it is, watch and make sure you can still get airflow through the fins so it doesnt overheat.
If the 07 is anything like the 06, very susceptable to bending the radiators if the bike is laid over; invest in a good pair of radiator guards. We use the European Yamaha guards. they work very well.
I untwisted a rad by putting it in the oven for a bit to heat things up & cranked it the other way. It came out almost perfect. A bit at a time works. Don't get it too hot. Much less screaming with oven mitts or welding gloves on though.
As long as it is not leaking I wouldn't touch it.
I had a small crush on my old bike, where one row was crushed. It didn't leak for the entire 2 years after it happened. I had a temperature gauge and it didn't make a difference.
on my 06 both are bent and it runs fine.. as said above just be sure u can see the air flow thro and there are no leaks. if thats good i wouldnt worry about it
Or you could send it too www.motorcycleradiators.com.
