Got Brembo?
I do .... and from the little riding that I have done, this setup is awesome. Will give it a better test this weekend and report back.
140
:bonk:
What parts (P#'s) were needed top do the conversion and where did you source them. What was the parts cost?
Is that a different disk too?
You will need fork lugs from an RM - the post by Nate has the years. You will also need some custom machine work done for a spacer. The part #'s and prices I will have to get back to you on.
320 Brembo disk.
i like it!
Thanks!
he went all out and swapped out the fork lug.very sano.
Thank you sir!
:bonk:
Cool setup, but I see the OEM fork brake mount is still on the fork, I though the whole idea behind having radial mount brake caliper is to have stronger connection between the caliper and forkleg.. by using a caliper adapter to mount the radial brake caliper, the braking force is still limited by horizontal strength of the bolts holding the brake caliper adapter.. though I've never seen a brake caliper bolt snap due to excessive braking force.
Until a fork lug comes out that will allow me to take full advantage, I can live with this.
Maybe I'm getting old, (42) but sano was a very common term around bikes back in the day...
Hey, that was my 500th post! Very uh, SANO!
What year RM is the lug from, which model, a 250? I would have to source a complete inner tube, unless the lug is available seperately, correct? I have never taken a USD fork apart. How is the lug attached?
The spacer is for what, the caliper?
I want all the sorid details.
This is the first big brake I have seen for a SM that I like that uses stockish forks. I saw one other but the had big $$ Ohlins on it.
Mine are from an 01'125 - other years can work (47mm Showa). Look for a post by Natethegreat he has a pretty detailed post regarding RM fork differences. Correct, I dont believe you can get just the lugs (you need both sides). I had the shop swap them during a revalve - they screw on. Or you could use the entire lower tubes. The spacer is for the wheel (brake side) - the lugs are different then the stock units and there is more of a distance so in order to center it you will need to get one made up.
Gotcha.
Do you recall how much wider a spacer you used?
5mm - other year lugs may be different. Keep that in mind.
I understand.
I did a seach in the TT classifieds, no listing for forks. Did a retail price check on RM inner tubes, Yowzza - $356/Each.
Might be cheaper and easier to simply make a new lug out of billet. Plus I'd be able to use the true radial mount. A simple project that is complex to execute. Down at the bottom of the 'To Do' list.
I understand.
ebay is your friend here.
