yamaha coolant + kawi coolant= ?????
i have a 125 im running low on coolant i have engine ice in there right now im going riding tommorow and dont have time to get more all i have is kawi coolant is it ok to just put the kawi in or should i drain whats in there first:crazy:
How can coolant be brand specific? As long as its safe for aluminum, you are fine. I would not mix coolant though. Drain it and re-fill.
got a few bottles of water? bottled water is distilled so drain the old,flush with water and add watever coolant with distilled water...good to go!
tap water has junk in it thats not good for aluminum
if the coolant is just abit low you can just top it up with water, distilled water is peferable but if your only gonna add abit then tap water will be ok too.
On the engine ice bottle is say "do not add water to." Im sure it wouldnt hurt I just wanted to point that out to you.
