X subframe on an R
Has anyone put an X subframe on an R?
I have an 02 450R and want the airbox/battery compartment from the X. I know the generation from the year difference is probably a factor...When did the first 450X come out? 04 or 05?
Thanks guys!
As far as the subframe fitting I am not sure if the fitment would be right but I imagine it might be ok if you use the seat off of an x, you would also probably have to put on the x airbox. Then again I am not sure if it will work.
As for the first year the x was available it came out on 05.
I hope I helped you some.
