Help!!!!!!!!!!
First define INSANE, then if the surfaces match and you can connect the hoses and throttle it may just work. If the ends don't match up just right you will need to make mounting adaptors and cobble it together. Usually it is not the best choice but you can do anything with a little time and a lot of money. Just a matter of how much you have of each, more time less money!!
Is there a difference between a 2 smoke and a 4 stroke carb? I can't think of why it would be different.
Most high perfomance 4 strokes have accelerator pumps on their carbs to prevent bogging when opening the throttle. When the throtle is opened air flow through the carb venturi slows down causing it to draw less fuel. The pump makes up for that. Maybe other differences too, some 2's have mixture screws that control air instead of fuel. Don't know if that's typical.
