Results from Zip-Ty $100 carb mod.
After hearing some good things about Zip-Ty, I gave them a shot...what the hell it was only a hundred bucks. When I finally got the carb back it leaked out of the float bowl o-ring. I had to grease the o-ring and reinstall and that cured it. To be honest I don't know if I feel much of a difference...I ran my stock carb while they had it for two weeks (don't send it through the post office!)...go Fed Ex. just having the 39mm back on is a big difference...if I got any gain it is minimal....2006 DRZ400s,YoshRS3,air box mod,39mm. Will try Eddies jetting suggestions next. EMN needle,third clip,200 main air,45 piolet jet, remove pilot air jet, 2 turns on fuel screw
