Rhc Exhaust Cam
I'm Installing New Cams Purchased From Rhc. Do I Need To Press Off The Gear On The Exhaust Cam In Order To Transfer Weights To New Cam? Whats That For? Any Help Is Appreciated!!
Those cams are set to run as is...No you can't transfer the compression release...it's cut into the cam not just pressed on...you just won't have a compression release unless you put the manual kit on. Due to their design, RHC cams don't have any starting issues with compression anyway.
:bonk::naughty::D
CC
