Adding Fork Oil Without Disassembly???
I was wondering if it was possible to add fork oil to my 06 RMZ250 without having to remove the forks. I have a leak and will be replacing the seals next week but want to go for a ride today. Can it be added through the ai bleeders?
it can but its not easy.
Real easy go through bleed hole with some kind of (siringe)not sure spelling or loosen the cap and lift it a inch or two and add what you need.
Have an assistant push the forks down and hold (about two inches), when you inject the fluid have the assistant raise the forks back up at the same time. Kinda sucks the fluid in:thumbsup:
