1989 yz80 powerband ploblem
it runs fine until a second after the powerband kicks in then stops pulling in the band , any body got any ideas what could make it do that
it used to run good like scream in the band and have wheel spin and now i got it running again , it has no wheel spin soon as it kicks in the band it dies out in every gear
When was the last time you did a top end job or even checked he compression? How's the air filter?
before it broke down it only had 9 hours on it if that , new air filter and it broke down because the crank seal slid donw the crank shaft and was causing it to get 2 much air
does any 1 have an 86-92 yz 80 if so what ratio do u mix ur gas at, i mix mine at 40:1
it allready spews from the header and i think that means to much oil in gas and isent 32:1 more oil
It's not because there is too much oil in the gas, it's because the bike is jetted richly.
it sucks the gas down quick , ill fill it up and ride it within a 30 minutes im almost out of gas does that have anything to do with my jets
stuck powervalve, take it out and clean it alot
It doesn't have a powervalve. :bonk:
ok, as silly as this might sound, check your silencer. Being that it's an older bike the perf tube could have broken and cocked sideways (had it happen). That would only affect high air flow performance.
just stick a yellow powerband in there :bonk: im rockin a purple now
whats a yellow powerband and a purple powerband are u makin this up cause thats the dumbest thing ive ever read
