WHen to replace valve seals?
I am going to build my kicker top end today. Only problem is I don't have any valve seals to do the job with. What is the best way to test the valve seals for usage or replacement?
i would wait and order them since you are gonna be in there you can tell if they are leaking because you will have an oil fouled spark plug ,assuming its not fouled they are probably ok,but if it were my bike they would get replaced now
THanks guys.
I had to have something to do today, my wife is on the recoup from the D&C procedure the did on friday. The head was going to be my job, but I decided to split the cases and replace the crank with the hotrods for the 500cc DRZ. I just got finished with putting the cases back together.
