xr100 getting to much gas
i have gone over the cab 5 times and no luck in getting the to much fuel thing straightend out i just put the motor back togather could it be the timing its getting so much gas it smokes need help:banghead:
How about some backround? You just get the bike, new engine, old bike that just started smoking, color of smoke, what's it smell like, etc. Is the carb overflow tube clear? If its plugged and the float valve is leaking through it will be rich. Did you try to clean a jet with a drill bit and maybe opened it up? Bad rings? Bad valve seals? Too many possibilities, not enough info.
