Compression querey
Hi have asked this question before but just wanted to double check
Iv got a 12.5:1 440 big bore kit on the way but i need to get a base gasket.
Of course i want as high a compression as possible but need to be able to run it on pump fuel approx 95 rating.
My bike has hotcams int&ex stg2(ithink) or the original 1s, and the cvk40 carb
Does any1 know if this set-up will run on pump gas with the E base gasket?
If i need to get the S gasket will i lose much performance compared to using the E?
Thanks in advance dan
I have the Athena 440 Big Bore kit sitting in my garage but before I install it tomorrow, I have a question I believe somebody will easily answer.
I assume that using an E base gasket instead of the 2-ply gasket included in the Athena kit should give me a little higher compression than the advertised 12.3, correct?
Can the included piston handle that kind of comp or do I have to get a high comp piston?
Any idea what the compression ratio will be with the 94mm Athena piston and E gasket?
Is the single-ply gasket that came with the athena 440 kit same as the E base gasket?
I compared them and they look identical. The 3-ply gasket is identical with the S gasket.
Can anyone tell me what the compression with the hi comp piston would be with the 3 layer gasket? And with the one layer gasket?
Thanks!
