How to disassemble seal head on KYB's?
A friends KX125 93's shock is over and I want to give it a complete rebuild.
Everything went good so far but how to remove the oil seal in the seal head? There is a lip on top, bent inside so the inner metal plate cannot come out.
1. What to do to unpeen it?
2. What to do to peen it again?
replace it- they are cheap.
i cannot replace them for cheap as i am in a country where this kind of parts are not available. i have to order from outside, this takes long time and costs...
therefore i need to open it.
Time = money...how much is your time worth? Whole seal head is around $35.00 US.
is it easier to get the oil seal instead of the complete seal head? :bonk:
@KTM-Lew
this one unfortunately is more expensive. it sells at 45 Euro (khan is from Turkey) which is +50US
I have rebuit these a few times, I just get out my Fordem porting tools or Dremel and remove just enough metal to get the bushing/seal out. Reinstall the new stuff, then peen with a punch atleast every 1/4 inch all the way around the where the old "lip" was. Never had a problem.
Worked for me but of course ,it might be safer to by the whole seal pack:ride:
i managed it!
just used a round iron which is quite big round and fits inside the seal head peened edge.
then hammered the round iron that it gives the edge a hit to bent out. done this all around the peened edge and that's it!
now I got all parts from it out, changed the bushing and will try to find a new oil seal.
thanks guys!
i managed it!
thanks guys!
Good idea, I have a small lathe now, so next time I may take your approach of no metal removel. I can just machine up some kind of big punch.
Mx-tech.com has seals.
I use a small screwdriver to first pry the rubber out. Then I use a small set of "ignition" plyers and just grab the lip and peel it back. Go all around it with the plyers about a 1/4" at a time. Takes me maybe 3 to 5 minutes to rebuild a seal head including the bushing. 👍
doc
doc
Genius:thumbsup:
Doc`s probably done a few.........hundred:ride:
Genius:thumbsup:
Been a cpl here & there over the years.......👍
doc
