Throttle Position Sensor??
Just cleaned my carb and getting ready to put everything back together, was reading through my manual just for the hell of it and found this - NOTE: "Do not remove throttle position sensor unless it is necessary to replace it." - I've had mine off a couple of times, what's the reason for not removing it? Did I screw up any settings? Thanks!
I think is refering that it is not necessary to remove the TPS to clean the carb. However with any sensor or component of this nature, it is fragile and removing it mutliple times can result in damaging it. I would run the TPS test on 12-16, if you are good, then I would not worry about it. However if you read the installation procedures on 12-17, it indicates you may have to adjust it for resistance when reinstalling.
