Lets see your DR's
Lookin at buying a 650 in the future and was just curious to see how everyone is setting up there bikes. I will probably do a SM conversion. Lets see those bikes :applause:
My wife and I were out for a ride today. Here's her '05 DR650 with my '06 DRZ400 behind it.
Well it ain't no Super Mo-toe, and it's pretty much stock from what you can see,,,,,,
Great pics,i especially like the MRvvrroomm one's:worthy: ,my project is coming along slowly, i'll put pics when i'm done.
Mine looks remarkably like most DR650's :applause:
As I got it: Corbin, screen, ventura rack, scottoiler + Added Gilera mirrors.
Test ride on Mitas E-07's - I like.
Having some fun...
Re:first pic DR 650 and DRZ400
First time I have seen a DRZ fitted with a topcase , how did you do it ?
I am asking, because one of the reasons I got a 650 is because it had a support for a solid rack , unlike the DRZ.
I left my motor stock but added fat bars, bark busters, skid plate, smaller front sprocket, stiffer springs and Race Tech valving front and rear. I also replaced the seat foam. BTW the way, that $15 Wal-mart atv seat pad (Stearns) works great (not shown).
http://www.dualsportridersoflouisiana.com/photopost/data/512/Red_Dirt_April_16th_2007_013.jpg[/img]"]Red_Dirt_April_16th_2007_013.jpg
Tlinza -
Please tell us about your low front fender. I like it. Thanks.
Rick
it's the stock mudguard. one of my philosophies is recycling whatever i can and use whatever is on hand.
i duct-taped a 3/8 or 5/16 ID hose to the center of the tire. put the mudguard down on the tire, lining it all up takes patience, then mark it. trim it down to an acceptable shape. i used a dremel with cutting wheel. then i found some alloy strap, around .750" by .125" i think, and used the fork slider plastic brackets as tie points. longer screws for the brackets & lock nuts. i used the stock hardware to fasten the fender to the straps. after it was mounted, had to bend it slightly to straighten it. the straps are thin & easy to bend. havent been through more than a puddle yet, but seems to work fine. and its stable at speeds to at least 90mph.
The new Clarke tank kept me going on the Texas Adventure Ride.
