oil leaking ?
i have an 05 450 and i replaced the rubber seal behind the front sproket 2 weeks ago and now it started to leak oil again, is there something im not replacing that i need to replace?
You not only need to replace the seal but the metal collar along with the rubber d-ring behind it. If it is still leaking after that then your trans output shaft bearing may be worn out.
