• Announcements
    • Bryan Bosch
      Buy/Sell/Trade/Wanted   01/18/2018
      Checkout our robust classifieds for amazing deals on bikes, parts, accessories, gear & apparel
swade730
DRZ pics with the best background landscape
6,510 posts in this topic
New wildlife clearing. Old Still Trail.Sleep Creek near Shanghai, West Virginia
Looks like it was a fun place to ride!!
1 person likes this
New rox risers (2")and rental fatbar Rc high bend.
new front and rear sprocket 15f. 47r
new o ring chain
im 6'0 and this bar setup is perfect for standing
4 people like this
new o ring chain
I've got the stock bars with these risers. But I'm 6'4 and its still a bit short. How much more rise do those bars give and do the cables and everything reach fine?
IMG_3232.JPGI figure I've gained about 4" from stock setup.
i had to reroute the throttle cable as you can see in the photo
the clutch and front brake line is at the max . Any higher and I would need longer lines
i also changed the location of the ignition
Edited by axeman604
1 person likes this
I think I might have to go for those!
2 people like this
Sup  guys!
Cleaning out some stuff from last year, and came across these from my last good ride of 2016 at Wellsville Ohio - hope ya enjoy!
Edited by RC_ichard
4 people like this
Snow storm in eastern panhadle of West Virginia dumped 8" Tuesday. Thursday thawing fast.
3 people like this
Nice. Reminds me of a visit to a friend's house in Westfir a while back. Beautiful area. We ate a lot of berries and filberts.
your bike always looks to me like it has two rocket boosters back there :-)
1 person likes this
Was visiting central FL during bike week so I brought my drz:)
Here's a picture from Flagler beach.
6 people like this
The roads out of Westfir are amazing. I've ridden the Aufderheide hundreds of times on my sportbikes. Up the other way past Hills Creek Reservoir are great DS rides over the mountains 3 directions.
  • Similar Content
    • By deanmellor
      My top end went on m 98 cr 125, the needle bearing clip came out and broke apart and shrapnel got everywhere and blew it up. I cleaned out the top end and washed out the crank with the bike upside down. the bike starts up great and seems to run fine but im getting a weird di-di-di-di-di-di-di noise coming from the motor. i tried adjust the power valve and tightening everything but the noise is still there. Here is a link to a video where you can hear the sound. It gets louder as rpm's get higher and at really low rpm barely idling it goes away. I am pretty new to bikes and 2 strokes so any help would be appreciated.
      https://youtu.be/msfU8WCXg8E
    • By RidingWithStyle
      In need of Cycra Handguards (probends) for my bike. Need 1 1/8 clamp size for renthal twinwalls. Message me if you have any for sale at a good price!
    • By Markl5557
      Morning ,
        I am looking for recommended radiator guards for my 2017 drz400 I was looking into the devol metal ones . Any one have suggested brands? Replies are always appreciated !
    • By Ted Lukecart
      Parting out a 98 KX250.  NOTE: bike is not complete so if you ask about "price for all" it will be based on each part and only a 10% discount plus freight shipping.
      Parts List:
      2- Engine cases with new bearings installed (right & left) $350
      1- Case gasket set (new) $25
      1- Crank w/rod (new unused) $150
      1- Transmission gear set $100
      1- Set of shift forks $50
      1- Shift drum $25
      1- Kick start input shaft/gear/spring $25
      1- Clutch disk set $75
      1- Clutch basket $50
      1- Clutch pressure plate $25
      1- Clutch lever and input shaft $15
      1- Fly wheel $50
      1- Stator w/wiring $100
      1- Wiring harness $50
      1- Coil w/wire $25
      1- re-plated cylinder (New unused plating)(NO power valve assembly) $350
      1- Top end gasket set (new unopened) $25
      1- power valve assembly $75
      1- Piston/rings/wrist pin (New in box) $85
      1- Cylinder head $50
      1- Kick starter $15
      1- Shifter $115
      1- Clutch cover $25
      1- Power valve cover $15
      1- Fly wheel cover $25
      1- Carburetor (assembled) $100
      1- FMF Gnarly pipe (plated)(no dents) $150
      1- FMF Power Core muffler $75
      1- air box (stock) $50
      2- Radiators w/cap $150
      1- Fuel tank (standard MX size) $100
      2- Forks (stock) $250
      1- Shock w/linkage (stock) $100
      1- Swing arm $75
      1- Frame w/pegs $150
      1- sub-frame $75
      1- Triple clamp $100
      1- Renthal handle bar w/mounts $50
      1- Hand throttle assembly w/cable $50
      1- Skid plate (aluminum)(no dents) $75
      1- Front brake caliper $50
      1- Front brake lever assembly w/hose $25
      1- Rear brake lever $15
      1- Rear brake slave cylinder w/hose $25
      1- Rear brake caliper $50
      1- Clutch lever assembly w/cable $25
      1- Front wheel w/brake disk (no tire or tube) $50
      1- Rear wheel with brake disk (no tire, tube or sprocket) $50
      1- Front fender (new unused black) $25
      1- Seat w/good aftermarket cover (black & green) $25
      All prices include shipping To Washington, Oregon, Idaho, Montana.  Outside the Northwest I will add additional shipping cost based on your address.
      Call or text for pictures
