Yosh ti
Why when I search on Yosh's website the ti model doesnt come up under the sm option? It just appears under the 400, is it due to the emissions and the fact that it is an off road model? This doesnt present any problems while installing right?
Its listed under the E model!
And it will fit, just search and there are MILLIONS of posts on this subject!
Yep, it is the E model and it will fit. If you want to retain your pasanger foot peg, you will have to do a slight mod. Search feature works great, because I gorget the title of the thread for the mod. I know eddie wrote it up though.
its listed as for the 400e, there are about 10 million posts and walkthroughs on installing the Ti on the 400s/sm. Please use the search function
Wow thanks, I understood that it was under the E model not the s/m. Sorry I didnt search it and will do so in the future.
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
