1983 XR80 Carb problems (maybe)?
Okay, I have an 83' xr80 that hasn't been cranked in 3 years. Here is a list of things that I have done to the bike:
New Air Filter
Cleaned the main jet (can see through it)
New slow jet
New float
Let Carb soak for 3 days, blew everything out with the air compressor
Changed engine oil
Okay, here is the problem I'm having:
Bike starts fine.
Bike won't idle right. Idles high, I adjust it, pump the gas, then idles to high again. Then I adjust again and it idles to low!:thumbsup:
Then when I'm riding, it will ride okay at very low rpm, but if I give it just a little to much throttle it will bog, but not shut off. can anyone help :thumbsup:
You sure you aren't mixing up the mixture and idle speed scews?
The speed is on the centerline of the slide. The mixture screw is on the airbox side of the slide. It should be lightly bottomed then backed out about 1 1/2 turns to get it going then adjusted as required.
