Power loss at full throttle pinned 3rd gear? jetting or other prob?
Hi, i was out riding tonight and towards the end of the night (after an hour riding). when i was hitting the 90ft step up in 3rd gear pinned (the lead up was rutted so the bike got revved out sort of fast)
the whole night i was hitting it no probs and the bike sounded fine and would rev out okay.
then at the end it sounded like it had no fuel, as if the fuel line was clogged so i pulled off and revved up my bike and then it wouldnt take full throttle and would not hit the rev limiter but make a weird sound.
at 3/4 throttle it would hit the rev limiter..
im not sure if i need to re-jet a little, im not sure where to even make minor adjustments even, do i lean or richen?
or maybe it was a dirty air filter? i only put an hour ride time on but it was a failry dusty day?
i have been told before that on a straight when i chop the throttle it does backfire a little - are these 2 things related?
advice? thanks
also: i have never had a probelm with bogging even after riding in the sand for an entire day??
its an 07 suzuki rmz-450! i know its not a honduhhh too, lol -
any idea's here
Well-tuned bikes tend to pop on decel without an ACV.
It sounds to me like it's leaning out past 3/4 throttle.
Some things come to mind:
air cleaner (check that it's clean)
Spark plug: clean or replace
Carb: clean jets and emulsion tube.
Give it a bash after each of those and see if that takes care of it.
so from what you are saying is that its probably not a jetting problem here.
which would make sense since the bike was running fine ALL day long and on the weekend too with no problems.
the air filter was dirty, so maybe that was a big chunk of the problem?
maybe it was some dirt running through the carb?
but you are recommending not to make any carb adjustments?
----what are those quick adjusters that you can buy that go under the carb called? are they worth anything?
thanks again
Well, I'm kind-of saying that. I dont' think that you need to change your jet settings, if that's what you mean. :thumbsup:
Here are my reasonings:
If the air cleaner is clogged, the bike will run rich and might not be able to pull enough air at WOT to rev up. Cleaning or replacing it eliminates it as a source of the problem.
If the spark plug isn't reasonably clean, the bike can have issues with a lean or rich mixture that it could otherwise handle. Replacing it eliminates it as a source of the problem (you can see where this is going...) :busted:
If it isn't either of the above, it sounds like your main jet (circuit) is partially clogged and limiting fuel past 3/4 throttle. This will tend to make the bike run lean past 1/4 throttle and get worse the wider the throttle is opened. Taking the needle and main jet out and flushing the emulsion tube and those parts should help with that.
Dirt can also get into the air jets (inside the carb intake bell) and make the bike run funky.
Another thing to check is the float valve to see if the valve or screen is clogged. If the bowl fuel level can't keep up with demand from the main jet, the bike will also run lean and can suck air through the MJ at high throttle positions. Some dirt in the gas tank might have gotten into the carb. Back-flushing air or carb cleaner through the float valve should push any junk in there out.
The fuel screw is the quick adjuster that you're mentioning. Yep, they're definitely worth the $20 and really make it easy to adjust the pilot circuit as temperatures change during the day. The TT store sells several versions of them.
Good luck with this. It's probably something really simple - just a matter of grinding away at things until you find it. :thumbsup:
Thanks for the advice David9999 thats much appreciated. i will try to work though some of the issues tomorrow taking the carb apart and giving it a good ole' clean.
it has 20 hours on the bike so maybe its time?
one thing i should mention that i dont usually use is: i was using a twin air filter (like always) and i put on a filter skin - the skin seems like it is made of a more dense material than the filter making it easier to clog? perhaps that was the problem and why it may have been starving of air?
just another thought?
Filter skin: It's not supposed to do that, but there is less surface area on them so maybe that's it.
I don't use a filter skin unless I'm riding in sand. I usually just wrap my airbox in a pantyhose leg for that anyway. :thumbsup:
No brakleen in the carb btw. It tears up the seals. (forgive me if you already know this)
I agree with the Air filter since the bike ran fine earlier..
When i had 04 125SX i was hitting a step on step off triple. and the triple was pretty close to a wide open jump
at the end of the night i was soing it one more time and i landed the stepoff, pinned it, backed off real quick, and pinned it...
The bike bogged and then would not rev out clean......i didn't make the jump good
Cleaned the filter and the next time i was at the track no Problems
So clean your filter and check it,, i bet it will run fine after that
  • Similar Content
    • By Sammy_1101
      Hi Guys,
      So I recently bought a 1997 XR400. I've done some research into getting more power through some basic mods and rejetting the carbs. Though all of the ones I've found have been for post 98 XR400s so the stock carb set up is a lot different. Usually people are opening up the airbox, exhaust ect. ect. and Jetting their carbs up to 160/162 for mains around 60 ish (I think) for the pilot. However for the 97 model this is close to stock for the jets.
      So essentially what Im asking (Just to cut to the chase ) Has anyone got a 96/97 (maybe 98, not sure) XR400 and has done these similar mods, and what sort of jetting have to done as a result.
      Thanks in advanced, also its my first post so apologies if I havent done everything correctly.
    • By Jturn
      38MM Cast SmartCarb. Purchased a couple years ago for a yz250. Don't have the bike anymore, and it has been sitting around for about a year. Used, but in fine working condition. You can also purchase a different needle for different bikes, as well as rebuild kits from their website.
      Asking $250 shipped to continental United States. I can arrange other shipping options at the buyers expense.
    • By faizakhtar125
      Hey guys I just bought a bike last night. So the seller said the bike will turn on but then die. We didn't try it because it was really late at night and it was raining (seat was wet). But he said if you bump start it, it will turn on and ride. So what do you think the problem is? I just want to make sure it runs... I probably won't be able to bump start it till Saturday (rain)... It's a four stroke, and I know absolutely nothing about them. Thanks.
    • By knotduke08
      I know this topic has been discussed in the past, but I have not found any options available for the new 2018 bikes. I live and work for a new Beta Dealer (Auburn Extreme Powersports) in California, and we are having a difficult time mapping the RR-S bikes for full FMF exhausts. We have tried contacting Beta Support several times for this issue to no avail, and we typically are given the runaround when transferring to techs and secretaries. From what we can gather, the FMF flash is designed for the RR bikes, but not the street-legal counterparts. Every time we try to install the FMF map onto an RR-S errors occur, and the programmer screen goes virtually blank. We have heard through the grapevine that some are using the RR maps on the RR-S with success, but we have yet to try it, even on our own bikes for fear that it will permanently erase or damage the CDI. Any and all help or suggestions regarding this topic would surely be appreciated! Thanks, Ben.
