new 06 - have some questions
1. How do I check/change the spark plug? Do I have to pull the tank each time?
2. What's the best type of chain to replace the old one with (O-ring, X-ring, no-ring) and why?
Just got my new (used) 450 a couple days ago and I'm lovin it! Love this site too, learned alot already. Thanks in advance!:thumbsup:
have never checked the plug out of 4 years of having 4 stk. yes you have to remove the tank. we race mx so we use non o ring chane. i also have a 06 450f.:thumbsup: :thumbsup: :busted:
thanks Thomas!
Would like to hear what others think about chains on these beasts!
FWIW, I'm a heavier rider at around 280 and would want whatever would be the strongest for my peace of mind! Between my weight and it's torque I'm giving my chain a workout!
What a great bike! It's nice feeling knowing you're on one of the best dirt bikes ever made! I've mostly owned 2T's during my adult life (mostly KX250's) and back in '93 I bought a new XR650L dual-sport, my only other 4t. The 650 had power but it was a tank to ride! The 450's more like my KX250's to ride. Nice!:thumbsup:
I think if you want lower maint. and higher strength you should probably go with o-ring or x-ring chains. My personal vote is for RK chains. I have an '06 too but I race motocross so I run a non o-ring chain. It makes me think I'm faster :]
rock on.
rock on.
Without a doubt buy yourself an x-ring chain. My last ert DID chain only lasted 15hrs and my new x-ring chain has over 25hrs on it and I have only had to tighten it once.
Hey thanks for the responses. I've decided on a DID 520VT (t-ring type) chain; tensile strength and wear rating were right up there with their best O-rings and it's a narrower chain to boot - more like a std 520 (mine already slaps against my subframe).
Decided on Ironman sprockets as well. Spoke to them on the phone today; very nice and helpful folks there. Hopefully this will be a "bulletproof" drive system for the next few years.:thumbsup:
Another question, please.
Does anyone remove both bottom oil drain bolts during an oil change?
Why does the owner's manual tell you to do this?
I remove both bolts but I don't have any specific reason other than "That's what the manual said." I tend to be a little on the thorough side, retentive even, when it comes to maintenance but I wouldn't be surprised if a lot of people don't take both out. I even read the ENTIRE manual front to back. Hints of OCD...
at any rate.
rock on.
make sure to chk your oil screen:prof:
On my "to-do" list. Thanks!
Also, I did order a metal "y" water fitting from the '07KX450F for mine.
how i had a chunk of silicone in my oil and i heard thats whats on them hen you buy it
