Buddy peg eliminator bracket.
I saw a post for someone looking for a bracket to remove the rear footpegs and still have something to mount there exhaust to. You can buy one for $24.95 plus shipping or you can do what I did for free. I had to add a few washers to the front and back so the exhaust would clear the rear shock spring but it works great. The one I'm holding was a rough draft. The holes were to big. I posted this a while back but figured I would again cause someone asked. All you have to do is copy your bracket,cut it out and grind it to fit. Picture038.jpg
Good job! But what do you do if you time is worth more than the 25 bucks?!:thumbsup:
I did it while on the job so I was getting paid anyways.
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
