Fouling a lot of spark plugs...
Well I am real new to two strokes. I had my Yz for about three or so months and I am still fouling spark plugs. I ride in trails and sand pits, when they foul I am usally in a tight spot where I just hold in the clutch and manuver myself out of it. (IE:Rocky parts on trails). Is this because I'm not revving it up?
Thanks just let me know if you need specs of my motor, its somewhat worked.:thumbsup:
My first few months i went through 60$ worth of spark plugs, then i started to learn about jetting, coming from an air cooled 4 stroke which never fouled plugs it was all new too me. So find a jetting guide and print it out and memerize it :thumbsup:
Not reving high enough can cause plugs to foul so if your just trial riding without long wide open sections, you can maybe get a hotter plug, br8eg instead of br9eg. this will burn off that excess unburnt oil thus cleaner spark plug.
But try to rev high dont keep it at 1000rpm if you know what i mean, but jet your machine for what your riding style is and you'll be sorted!!!
Hope that helped
Alright thanks, I bought the bike from a guy up in the Catskills, I'm all the way down in NE PA. Do you think the jetting could be different because of the lower elevation?
Totally temperature altitude effects it, I bough my bike from a guy who practically lived on top of a mountain and i live near right at the sea on the coast so when it was up there it worked perfectly the day i brought it down to my house it fouled, those plugs where so wet. Have fun sorting it out its all worth it in the end the power of a properly jetted 2 stroke is better than what pipe can do for u. IS it a 125?
Its a 2003 Yz 134, port and polish v force reeds FMF SST and FMF shortie and a few other things.
My plugs were extreamly wet and completely black when they foul. So you guys should think I should rejet?
Without a doubt, rejet now before u waste any more plugs
  • Similar Content
    • By Mikeybabbel
      Hey guys, I just picked up a running 03 yz125 a few weeks ago and upon tearing down the top end, I noticed the cylinder head looks a little beat up. Is it possible to just clean it up or am I better off just buying a new one? Thanks guys.
    • By faizakhtar125
      Hey guys I just bought a bike last night. So the seller said the bike will turn on but then die. We didn't try it because it was really late at night and it was raining (seat was wet). But he said if you bump start it, it will turn on and ride. So what do you think the problem is? I just want to make sure it runs... I probably won't be able to bump start it till Saturday (rain)... It's a four stroke, and I know absolutely nothing about them. Thanks.
    • By neonmarine
      Hey guys,
      I've used this forum as a "guest" for awhile now and I thought I'd share my build now that it's all coming together.  The primary purpose of this project is to help me train for roadracing my 2009 R1 at lower speeds as well as giving me a cheap alternative to racing the big bike.
      Here's what she looked like when I picked it up from a local shop.  Paid $800 cash for the bike as you see it with 17' rims, FMF pipe, EBC 250mm front rotor and clip on handle bars.
      Fits PERFECT!
      Shake down run at the Herrin Compound last summer:
      As she sits today:
    • By 125 yamaha guy
      i bought my yz125 from a dealer and they said that the clutch was broken so i bought it and it worked fine it would run move and everything and then it started to act up and now only first gear works barely though. when you put it in first it acts like its bogging down but its not and when you go into gears 2-5 it wont move i dont know whats wrong with it im assuming the clutch is slipping or something if you know please leave me a comment
