07 RMZ, suspension settings
hi guys,
i have an 07 rmz 250 . i already installed lighter fork/shock springs . I have .40 forks springs and a 4.6 shock spring. Now I would like my front end to be more plush on square edge bumps. what would you suggest me ? lower oil level ? 2.5w fork oil ? i weight 130 w/ gear on and race junior class . thanks for your help .
have you tried the compression adjusters? what are they set to now? you should try lowering the oil amount if you are not bottoming now, a 2.5 wt in the inner cart will make it a little plusher.
