multipile part #'s for water pump housing? which one?
ordered part # 17410-29F01 from ronayers for the water pump other housing, but later noticed there are 3 different part #'s listed for item #8 for a 2002 DRZ400E model. One of being discontinued. Anyone know the difference between 29f01 and 29f21 ? I ordered 29f01, is that the right part #?
17410-29F01 - 8-1
17410-29F20 - Discontinued (8-2)
17410-29F21 - 8-3
superceded part numbers.
so theres only 1 part? if I ordered either part #, they are automatically going to send me the right part?
yes,17410-29F21 is the latest #
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
