It won't work X Trans Gears In R Trany
Well I Split the cases found out for my self that you can't swap all or any gears from X to R CRF250 the main shaft is 30mm longer on the X and the splines are different (6) on the R and (12) on the X I guess I'll have to live with it. Would have been great to get some more top speed for my plated R model.
I thought you could, I have both gearsets setting on a shelf. I will double check but I suspect you are correct..
damn, this is what i was going to do, if I ever got hardcore with the R.
