kaxamotos
Fastace forks, billett hubs, billett kick start, removable sub frame,...... It's got some nice components, but what motor is in it? What's the price?
My guess is that if you see it up close, it'll be easy to tell where the corners were cut.
On second look, that swingarm looks a little thin.
its a 140cc jailing motor
Are Jailing's good engines?
Yep, mods galore!!!
the KXP-01 is 850.00 sdg 125 or 140
If that's a Jailing motor it's the only one in the lineup, the rest are all Lifan. I can't find the specs on the kxp-04 but I bet it's a Lifan too.:thumbsup:
Why are Lifan bad?
this one has a jailing
http://www.kaxamotos.com/productdetail.php?id=67
the jailing is the same as the gpx motor that they put in the pitster pros, (has a different shift pattern) they are suppose to be the best
the sales guy said that you pick if you want a jailing or lifan so dont look at the spec where it says the motor
Jialing does NOT make a 140cc.
kaxa is a manufacturer in china ... you would have to import them yourself, which means that you need EPA certs for the bikes (motors). KAXA has NO EPA CERTS except for their 90 and 110 quads. So good luck getting them here and through customs without the required docs. Or you could try to get them epa cert'd yourself (wait months and spend thousands) ....
