help! increase trottle response
This is my first post. I have a klx 250 s...I'm unleashing a beast... It have a pro circuit t4 install. 13t / 48t sproket combination... new barnett clutch and the machine its really starting to rip...But trottle ratio is to long...to many effort to have it open from none to full. I find my selt gripping and regripping the trottle to achive maximum power...sometims I think is full open and then i ralize it can still open a quarter turn more... What can I do...Is there any aftermarket trottle or any quick fix. sorry for my english I'm from Puerto Rico and I dont practice it to much...
A lot of guys go for 1/4 turn quick throttles, but I prefer the ratio of the stock throttle. It's easier to keep the front end end up doing wheelies; just better modulation all around. Better than all-or-nothing. My $.02.
There's a cheap - free - fix. You can drill another hole in the arm on the carb, about 1/4-3/8" or so from the existing one. It changes the throw and basically makes it a 1/4 turn throttle - and it's reversable. There used to be a picture on the planetklx.com site. Not sure if it's there anymore. If you do it, make sure to de-burr the hole because the sharp edges tend to wear on the cable.
OR - you can do the real fix and drop in an FCR. You won't be needing to whack the throttle wide open anymore. :thumbsup:
Or a TM33 for a whole lot less money.
Back on the original post the KX250F uses a 1/4 turn throttle and may fit. I'm not sure if they fit I'm just guessing.
And a lot less performance! :p
Less than from the stock CV carb...............?????? You lost me!
Less than an FCR, although I chose to stay with the CVK/dynojet kit over a 33mm mikuni.
So?? I'd still prefer a FCR to the mikuni - whether 250 or 300. The FCR has much more tunability and it's a better built carb IMO. But that's just my opinion after riding 300's/250's w/ 33mik's, 36 mik's, FCR's, Dynojetted CVK's, FSW jetted CVK's and stock kawi jetting.
IMO, the reason people don't get FCR's is because they don't have the money (ie: they're expensive) or because they're not willing to take the time to learn to tune them properly. Performance is not the reason. There's a reason why almost every manufacturer of high performance race 4strokes uses FCR's. Yamaha, Honda, Kawi (but not on the KLX), KTM, etc., etc., etc..
