hey guys just got a 50 and having a couple probs...
Hi ya'll...just joined the board after my gf bought me a 2002 xr50 for my birthday! :thumbsup:
having a few probs with it....
first off, after turning the bike off, it pisses gas through the vent tube for a few seconds leaving a puddle on the ground. any ideas?
secondly, after riding it in 2nd and 3rd gear for an extended period of time (10-20mins) (was walking my nearby roadrace track with it last week) the bike shuts down. it dont think its overheating as the motor isnt overly hot and there was quite a breeze as i rode around the pavement. once the motor stopped... if i let it sit for 5-10 mins it would start up again. :thumbsup:
another issue that came up after the shutting down, is id ride it for a short period of time (across the pits to the bathroom,etc) and upon coming to a stop the motor would just turn itself off.
anyone have any ideas? thanks ahead of time and i look forward to spending alot of time on here! :busted:
i don't know the answer to your other problems, ( I actually have them myslef somethimes).
But for your first problem, turn the tank valve off shortly before you stop riding. So ride until the carb doesn't have anymore gas in it, so it will shut down by itself.
check to make sure the drain on the bottom of the carb screw is tight
When I first got my xr50 it would come to a stop and just shutoff. There was to much oil in it and the air screw needed adjusted. So adjust the air screw and check the oil. :thumbsup:
Hope this helps.
I think its all fuel related, seems to me there may be something wrong with the vent cap, if its building pressure it may piss, if its building pressure it may also force to much gas into the carb flooding it...just a thought
The random turn off is weird. Check the wires by the key and stuff, see if its all in tact. :thumbsup:
thanks everyone. im out of town but will check all those things sun when i get back into town. im gonna have the carb professionally cleaned in the next week or so and they said they would solve the probs for me while they were in there. we'll see...
i just dont see the point in shutting off the fuel before i stop riding to make it stop pissing. it def should NOT be doing that if running properly. i hope the shop can figure it out when they clean.
your float is sticking or needle valve not sealing. you can easily fix this yourself.
your having some electrical problems, check your ground connection(under the tank where the airbox connects to the frame) and try disconnecting the key and kill switch. it will run without a key or killswitch. turn it off with the choke.
FiveO...how would i go about fixing the float and needle issue? i know pretty much nothing about carbs...:thumbsup:
thanks for all the responses guys and gals! :thumbsup:
Try taking the bowl off the carb, removing the float and then see if the needle and seat is damaged or dirty. Dirt in the bowl may be an indicator. If dirt gets stuck in the seat the float can't shut down the flow of gas and the carb will flood. clean everything w/ carb clean and a toothbrush, blow out all the jets and put it all back together and try it. You might want to check for dirt in the gas tank.
a float bowl carb works by a element that floats on gas and shuts off a valve that fulls the bowl with gas. when gas reaches a certain level in the carb its flow gets stopped by a small rubber needle valve. its a good system but even a small amount of dirt can keep the valve from sealing. there is an overflow built into the carb so if/when it does stick it doesnt pour into the engine. this is what you are seeing.
#3 is what your looking at. before removing the float move it up and down by hand and see how it moves the small needle valve, this will help you understand when you go to put it back together!
dont worry all you need for this job is a 8mm wrench and phillips head screwdriver.
FiveO...thank you SIR! :thumbsup:
thanks for all the replies. ill be tackling this job sometime this week coming up. get ready for some PMs :thumbsup:
  • Similar Content
    • By RCWSO
      I have an 07 CRF70 that I have done the filter pod modificaiton by cutting the extension tube off and I have drilled a couple of holes in the end of the exaust per some instructions on a thread here at TT.
      I have recently had some problems getting the bike to idle consistently. I am wondering if I should try and rejet the bike at all or get a needle from an older carb that is adjustable. I do have a unifilter that I can put in as well with the stock pod that I cut.
      It is not that the bike wont run or start, it just seems to only idle if I turn it up significantly but as soon as I turn it down even 1/8 of a turn it dies. But the idle that I set to keep it running well is too fast as the bike will move forward if in gear and no throttle is applied.
      Any suggestions? Jetting, needle, air screw change with an older carb?
    • By the-new-kid
      hello guys I'm like really new to this, like extremely new but I was going to buy xr-70r from a friend and drop a Lifan 125cc engine in it (here's the link: http://tboltusa.com/store/lifan-125cc-enginebrsale-price-p-1811.html ). Now the site says its a 4preed trans with normal gear set up (1-n-2-3-4), and manual front clutch, I'm wondering if I need to buy the clutch lever, perch, and cable then connect it all. Then secondly, what pip should I be looking for I'm not sure if the header would have to be a different style or what exactly.... please be patient with me I'm doing the best I can to learn... thanks
    • By anger806
      hi im new to the forum and i am running a stock 2005 crf 50f with pro tapers but no engine mods what size carburetor should i be looking for to get a little more pep out of my motor?
    • By HondaRacer37
      Hey everyone.  Darn glad to have found this forum!
      Just bought my son a 2009 CFR70 (first bike - 8 years old) and the first thing I'm doing is scrapping the factory air box for a UNI pod filter.
      I'm looking for advice on how I can open up/modify the factory exhaust for more performance.  I heard about removing the screen and drilling some holes but have not found those posts. Any specific advice would be greatly appreciated. (Found only a couple performance aftermarket pipes that were very pricey.)
      I'm thinking after the air filter change and pipe opening the main jet size may need to be increased. It's a stock 13mm Keihin carb.  What size is recommended?  Haven't looked at the stock size yet.
      I assume the needle is adjustable on the slide (but don't know if this would do any good or be necessary anyway) and hope there is an air mixture screw somewhere because it seems the carb could use a bit of adjustment now.  Although next to the idle screw it looks like a brass cap or plug rather than a screw. (See photo attached.)
      Thanks for any advice.  It's great to be part of this group.  Ride on!
      Greg in Florida
    • By thousandbuckle
      Hello all, reaching out to you today to get some help with a small project I am trying to do.
      I just bought a 2006 CRF50 for my 3 year old and would like to rig it up with a wireless remote kill switch for those just in case moments. I have the throttle speed screw installed and will limit it that way also but want a back up until she is proficient and I feel confident.
      Since this bike does not have electric start there is no battery. I was wondering if any one has or knows how to rig up a wireless car alarm system to work as a remote kill switch. I know I will need a 12 Volt battery on the bike which I can get. I know there is a product from 3Built that does this but the range is only 250 feet and some say it is even less than that. I was thinking of a car system since the range is usually around 1,000 feet which is overkill but I prefer overkill when it comes to this topic,
      Any DIY thoughts you might have or suggestions would be appreciated.
