Anyone Use the JD Blue Needle???
I remember back in the day when I got my jd needles and I followed the specs and went to put in the blue needle and it was way too rich. There is now way under any circumstances that I will need to use it. I have ridden my bike at 10 degrees farenheit when the oil was like molasses and it did not need the blue needle.
So is anyone using their blue needle?
i needed mine in the winter because my bike was hard to start with the red one whenever the temp was below 50 degrees F
so yes, use the blue one if you ride at below 50 degrees F:thumbsup:
Coldest I've ever tried to start the 450X was around 30F. It started but not easily. There were a few guys that morning using jumper cables.....
