merging 2 posts
test
1 member has voted
  1. 1. test
    • 1
      0
    • 2
      0
Overview
Rules
Husqvarna
Bikes
  • Armor & guards
  • Controls/levers/foot pegs
  • Fuel & intake
  • Engine cooling
  • Engine - including engine electrical, clutch, gearbox
  • Chassis - including chassis electrical, plastics, graphics
  • Drive
  • Suspension
  • Exhaust
  • Brake
  • Tire & wheels
  • Lubes & tools
  • Husqvarna Stuff
Overview
This information is a general overview of Husqvarna dirt bikes and as a reference for those who own Husqvarna dirt bikes. It is a technical forum that assumes a certain level of knowledge.
This information is intended to be accurate and up to date but may not be. Other sections of Thumper Talk contain excellent information that may apply to Husqvarna products as well i.e. jetting and carburetor set up.
The order the information is presented is based on several factors including the quality of picture available.
By it's very nature this information will never be complete - if it was then it would be far to long & difficult to maintain. Some information has been omitted intentionally for a variety of reasons.
Rules
The Husqvarna section of Thumper Talk has the same rules as the rest of Thumper Talk.
Thumper Talk rules
This is the most common issue in forums:
No posting for sale, free, wanted or trade ads in the forums, please use the classified section instead.
  • Put it in the classifieds and/or put it in your sig. Maybe someone will notice and make a post about what you have in the classifieds.
  • The Home Page in your profile can link to almost anything.
    In addition to Thumper Talk rules these will be considered trolling and/or personal attacks:
    • Posting personal information about others in a negative way.
    • Badgering people for information they do not want to give.
    As far as I am concerned the Husqvarna section of TT is doing just fine, but anticipate a rapid growth in this section of TT and need to be prepared for it.
Bikes
  • 2004
  • 2005
  • 2006*
  • 2007*
  • 2008*
* All TE's are USA 50 state street legal, TC's are California "green sticker" bikes.
The pictures may not show turn signals installed for the street legal bikes.
2007 Bikes
Special note - TE250/450/510 - in 2007 Euro 3 bikes were sold in Europe, and USA models were sold in the USA. Towrd the end of the 2007 model year some Euro 3 bikes were sold in the USA but not in California. Euro 3 bikes have Keyed ignition.
2007 TE250 technical specifications
2007 TE450 technical specifications
2007 te510 technical specifications
2007 TE610-ie tech specs (European model - fuel injected, USA models have Keihin carbs)
2007 TC250 technical specifications
2007 TC450 technical specifications
2007 TC510 technical specifications
2007 SM450R technical specifications
2007 SM510R technical specifications
2007 SM610-ie technical specifications (European model - fuel injected, USA models have Keihin carbs)
Armor and guards
www.Uptiteracing.com - if you want more information it is best to call, they also make a mid-pipe guard. uptiteskidplate001.jpg
www.roosterperformance.com
www.flatlandracing.com
CRD - http://www.crd-international.com/moto.php? - they also make a frame guard.
www.hyderacing.com
www.forceaccessories.com.au/
http://www.whipps.com.au/Products/BashPlates.html
Foot pegs
www.pivotpegz.net
www.promotobillet.com
www.rocstompa.com - the site does not indicate Husqvarna is supported.
Brake pedal
Shift lever
Shift levers:
www.imsproducts.com - the site does not indicate Husqvarna is supported.
Triple clamps / Bar mounts / Sub mounts
www.ptenduro.com
www.ferracci.com - but no clear listing for a newer Husqvarna dirt bike
www.brpit.com - the site does not indicate Husqvarna is supported.
Steering dampers
www.scottsperformance.com
www.motosportz.com
www.rttmotorsports.com - the site does not indicate Husqvarna is supported.
/www.gprstabilizer.com - the site does not indicate Husqvarna is supported but has been used on a Husqvarna.
Handlebars - this is way to big of a subject and too universal a product to discuss here - but here are a couple of companies:
www.protaper.com -
Tapper bars in Henry/Reed bend (info: Michael Lueders)
www.renthal.com -
Fatbar in RC bend (info: jr50kid) , 7/8'' in Husky bend.
Handlebar switches
www.kandstech.com
Throttle tubes
www.g2ergo.com
www.uptiteracing.com - makes throttle tube but not on web site.
Fuel & intake
Carburetor
Awesome post on the AP and how it works by Clark Mason (insert all relevant posts from the carb & AP threads)
Here is a short video showing the AP squirt:
Remove throttle stop and enable the AP
re-jetting a 2006 FCR-MX 37mm carb
Jetting kits
www.JDjetting.com
Misc carb parts & jets
Standard jets can be obtained for FCR-MX carbs from many places and other brands of bike dealers, in addition the Thumper Talk store carries many of them.
Odd leak jets are available at the OEM TT store, also:
The 2005 250x seems to use a 55 & 65 leak.
JET, LEAK (#65) 99108-KSC-0650
JET, LEAK (#55) 99108-MEB-0550
www.sudco.com
"Needle Set Screw" - Sudco part # 021-727, Keihin #1421-802-2000
This is what goes where the throttle stop was in the top of the slide.
Fuel mixture screws
http://www.scottsonline.com/products.php?PartType=59 - does not specify Husqvarna but have direct knowledge they work well.
www.slavensracing.com
www.bikebonz.com
www.stealthracingtech.com
www.ziptyracing.com
Also:
www.msrhp.com
O-Ring, washer, and spring for fuel screw
www.ziptyracing.com
www.JDjetting.com
www.sudco.com
Keihin part nimber.............."description".............pric e
KE 021.041.......................1290-812 spring.......$2.31 ea
KE 021.042.......................16075-KG8 O-Ring.....$0.63 ea
KE 021.045........................0301-803 washer......$0.53 ea
Air Intake Venturis
www.scaryfastracing.net
Fuel tanks
www.imsproducts.com - the site does indicate Husqvarna is supported but cannot download picture.
www.clarkemfg.com
www.gmxradiators.co.uk
Air filters
www.twinairusa.com
http://www.crd-international.com/moto.php?type=1&marque=13&modele=140&search_annee=&view=&view=8&ref=1051&langue=Gb#popup
www.hiflofiltro.com
www.knfilters.com - the site indicates paper is the only one available
Airbox cover - use while washing bike
www.twinairusa.com
Another site that seems to have unique products is - www.husky.com.au
How to check and adjust the valves on a TE250:
Programmable ignitions
http://www.vortex-performance.com.au/prod02.htm
Big bore kits
http://www.uptiteracing.com/big_bore_kits.htm - 310 kit for the TE/TC250
Athena's link would be here but they did not have a picture on their website.Uptitebigbore166-1.jpg
Pistons
www.gpmotorcycles.com - SM piston.
http://www.woessner-kolben.de/english/indexenglish.html - they list for 2st & 4st but no useful pictures.
Auto Clutches
www.rekluse.com
Slipper Clutches
http://www.suterclutch.com/slipperclutch_offroad.html
www.stm.to.it
Surflex - surflex@iol.it - can't find web site.
Oil Filters
Many Husqvarna's have a part # similar to KN-154. These make paper filters:
http://www.hiflofiltro.com
http://www.twinair.com/
http://www.knfilters.com/
http://www.scottsperformance.com/products.php?PartType=3&Bike=Husqvarna&PHPSESSID=ec3ab8e9f58ba7a76bafd5e3239a22d6
SS Valves
http://www.halls-cycles.com/Parts%20..._valves_04.htm
Valve Shims
http://www.hotcamsinc.com/index.cfm?fuseaction=cProducts.list&categoryid=23&enter=Go%21
Other
www.gpmotorcycles.com - SM.
Plastics
www.polisport.com
www.cemoto.it
m o t o p l a s t i c s u s . c o m - seems inexpensive.
http://www.carbon-performance.com/index_eng.php?kat_id=61
http://www.pro-carbon.com/scripts/zbozi.php?KID=56
www.ufoplast.com - can't find product info.
www.taliesinracing.co.uk - site is down.
This topic is now closed to further replies.
