greasing linkage on 05, need help
I'm such an idiot! I was greasing my linkage on my 05 crf and when I went to reassemble everything I forgot which washers went where. There four total, two different sizes, can any of you guys tell me which ones go where? Any help would be greatly appreciated.
I'd usually look into this but I'm feeling extremely lazy today (I love Saturdays. Here are the schematics, I'm sure you can figure it out from there.
A book / manual should be a necessity for every bike owner.
Are you following WRooster's Instructions?
Ref # Description Part number
1 cushion assy, rear shock 52400-KRN-731
2 spring, rear shock 52401-KZ3-J51
3 damper, rear shock 52410-KRN-731
4 stopper, spring seat 52419-KZ3-J21
5 rod, piston 52421-KRN-731
6 adjuster, spring 52422-KZ3-J31
7 nut, adjuster 52423-KZ3-J21
8 case, damper 52425-KRN-731
9 cap, air valve 52425-381-771
10 rod 52426-KRN-711
11 rubber, stopper 52427-MEB-751
12 plate, end 52428-KRN-711
13 case, rod guide 52429-KZ3-J41
14 ring, piston 52431-KZ3-J31
15 oring (3.5 x 43.7) 52434-KZ3-J21
16 oring (42.5 x 2.0) 52434-KZ3-J31
17 ring, stopper 52435-KZ3-J21
18 oil seal set 52436-MEN-671
19 nut, hex (12mm) 52438-KA4-741
20 adjuster 52440-MEN-671
21 bladder 52451-KRN-711
22 ring, stopper 52452-KS7-831
23 cap, chamber 52453-KRN-711
24 ring, stopper 52455-KZ3-J21
25 collar D, shock 52464-KRN-710
26 collar C 52463-KZ4-J40
27 collar D, shock side 52466-KRN-710
28 collar B, cushion 52464-KZ4-J20
29 arm, sub-assy 52465-KRN-710
30 collar A, conn rod 52473-KZ4-J20
31 collar, link side 52475-KZ4-J20
32 washer, thrust 52476-KZ4-J20
33 rod, sub-assy 52479-KRN-710
34 seat, spring 52486-KZ3-J21
35 ring, stopper 52487-KA4-831
36 label, rear shock 87516-KZ1-600
38 bolt, link (12 x 96) 90130-KZ4-J20
39 bolt, link (12 x 81.5) 90130-KZ4-J40
40 bolt, link (12 x 120) 90131-KRN-710
41 bolt, (upper) (10 x 53) 90152-MEB-750
42 bolt (10 x 43.5) 90153-KZ4-710
43 nut, U (12mm) 90306-KBP-901
44 nut, U (10mm) 90306-KZ4-711
45 washer, plain (12mm) 90501-KZ4-J40
46 bearing (20 x 26 x 14) 91053-KZ4-J21
47 bearing (19 x 26 x 13) 91074-KRN-711
48 bearing (10) 91074-MAC-741
49 oring (21.5 x 1.5) 91256-KZ3-731
50 oring (26.2 x 1.9) 91257-KZ3-891
51 dust seal (25 x 32 x 4) 91262-KZ3-731
52 dust, seal shock 91351-KZ3-731
53 dust seal (17.5 x 26 x 3) 91351-KRN-711
54 dust seal (16 x 26 x 3) 91351-MAC-671
55 washer, plain (12mm) 90501-KRN-710
56 bearing, needle (20 x 26 x 15) 91051-KSC-003
